Help with 2 mystery wires!! (79' camaro underhood)
I am rebuilding this 79'.. I have the motor and tranny back in but soon realized that something wasn't right... I cant find any alternator wires besides the battery "hot". The only wires I found are 2 red (1-10ga 1-12ga) mystery wires that come from the same part of the harness that the alternator plug and wire comes from... Could some one tell me if these wires are suppose to lead to the starter?
Normally the red wires are battery hot wires.
A picture would help. But an easy way to do this is the fuseable links will go to the starter. The purple wire goes to the small terminal and trigger the starter. There is one that runs from the starter to the alt.
This is how I roll on my wiring. I HATE fuseable links. HATE! It goes back to my teenage years before I knew much about anything. I dont like laying on my back with crap dropping in my eyes while I probe the wire to check them. Let alone trying to change one. My own cure was to get a 150A breaker and I mounted it on the fire wall by the booster. There are two fuseable links that "usually" come from the harness are terminated at the breaker. I have a 8g from the starter to the breaker. The breaker serves as a power distribution block now. I have the 8g to from the alt to the starter too. I also have a 140A alt. So 8g isnt really overkill. You could use 10g. Its cheaper to grab 8g in a Car stereo kit. Its more flexible and comes with terminals.
In the end I like having the block on the firewall. I can put the breaker in test and kill the power but still roll the starter with a trigger. Easy to run valves and what not without starting the engine.
