none of my guages work
Old Feb 14, 2014 | 02:23 AM
Araiza42's Avatar
Default none of my guages work
hi everyone just got my first camaro 81 z28 and today i turned it on and none of the gauges work speedometer, tachometer , fuel gauge none of them. what could it be? thanks for the help
Old Feb 14, 2014 | 06:43 AM
Everett#2390's Avatar
Speedo won't work unless Camaro is moving.
Gas gauge usually stays at the last indicated position when power was last applied.
Tachometer should work with engine running.
You might have a sticky/maladjusted ignition switch.
Giggle the keys/tumbler and check tach with engine running.
Old Feb 14, 2014 | 06:48 AM
check all your fuses.
Old Apr 2, 2014 | 02:04 AM
greencamaro1981's Avatar
turn signals? high beam indicator? dash lights? speedo is manual, do you have guages or dummy lights?
92 RS in training
Jan 25, 2009 04:56 PM
rs305
May 8, 2007 12:51 AM
Sinner1Camaro
Feb 11, 2007 11:29 PM
91CamaroRSc
Feb 24, 2006 04:10 AM
