Loud Rattle Coming From Steering Column
Old Sep 10, 2018 | 06:45 AM
mnmcollector's Avatar
Default Loud Rattle Coming From Steering Column
79 Camaro
Since we bought this car in April of this year it has had a rattle behind the dash. We thought it was the speedo cable. Replaced speedo cable and still had the rattling/grinding noise. We replaced the lock cylinder just because... and the rattlig is still there. I see a rod like cable runnig up the steering column and I am not sure what its purpose is but we can feel and hear the noise coming from under the metal sleeve that is coverig the steering column. Any ideas what this could be?
Old Sep 12, 2018 | 09:18 PM
Zspoiler's Avatar
I have a 1979 Z-28 RS and I may be able to help you.For I have rebuilt my tilt column in the past..Is it a tilt column? Or a column shift ? pictures would be a help.
Old Sep 12, 2018 | 09:49 PM
Y2K's Avatar
Y2K
Sounds like the tilt rod/cable alright.
Old Sep 12, 2018 | 10:01 PM
Cool Rattle
Actually I have determined what the rattle is. It is the neutral/park rod coming up the steering column into the key cylinder. I can feel it bouncing and vibrating inside the column. The gear shift would be difficult to get in to park and the key would not turn back all the way so I could not get the key out so I just turned the steering column by hand counter clock wise to release the key lock. I detached the shift link rod in the engine bay and took it for a drive and voila... no noise.. as soon as I connected it back and went for a ride the rod in the steering column rattled and vibrated. So I went under the car (sucking my gut and squeezing under it lol) and found the shift link rod was loose at right at the tranny shift lever. So I tightened it and the rattle went away only 50%. So I know what the problem is... I just can't figure out how to completely eliminate it.
Old Sep 13, 2018 | 04:56 AM
Default Rattle
Sorry no it is not a tilt column.
Jimmy Davis
Mar 8, 2014 02:57 PM
MJTate
Jun 25, 2013 06:26 PM
ckrummy
Jan 25, 2012 10:12 PM
sewerrat
Mar 4, 2008 01:39 PM
keemaro85
Aug 29, 2007 01:56 PM
