ZERO OIL PRESSURE
Old Jun 26, 2006 | 05:14 PM
speedy9220's Avatar
Default ZERO OIL PRESSURE
So there i was, driving my camaro and watching the gauges frequently. i glance over and i had zero oil pressure instantly. i immediately pulled over and had the car towed to my house. i pulled the motor and found gasket material in the oil pump filter and there was a large score on the inside cover that holds in the pump gears. one of the main bearings were scratched up a bit but not totally spun. i think i caught it in time before there was much damage. has anyone had a similar experience and what may have caused this? your feedback is appreciated. thanks
Old Jun 27, 2006 | 09:52 PM
abra's Avatar
Default RE: ZERO OIL PRESSURE
you found it....
has someone relpace your intake?, most common gasket in pan maker.
it sounds like a complet rebuld job, well almost.
hows the crank jornals look?
check the cam bearings also.
did you hear a tap tap noise?
did you run hot or smoke blow off the engine. those signs are never good.
you did the right thing
Old Jun 28, 2006 | 02:10 AM
Replace the oil pump and the oil pump drive, if the crank is not scored, replace all the bearings & you should be OK, maybe. All sorts of crud gets caught in the pump screen, that is the reason it is there; the problem is when it goes through the screen.
Old Jun 28, 2006 | 08:00 PM
speedy9220's Avatar
it looks as if the intake gasket got sucked thru. i ordered a new oil pump and hardened drive for it. i also ordered a new gasket kit rod and main bearings. the crank looked good but i sent it out to be machined anyway. everything else looks good.
thanks for your input,
rob
royco95
Aug 2, 2015 10:25 AM
BoricuaHec01
LS Series Tech
Mar 17, 2011 05:56 PM
angelus
Feb 20, 2010 01:17 PM
divineal
Oct 23, 2009 12:21 PM
IBSTROKIN
Sep 9, 2009 10:40 PM
