would these tires fit my 81 camaro?
Not positive,but i would say the 11" wide wheel will probably be to wide.I have an 8" wide rim with a fairly good sized tire and it goes from right at the lip of the wheelwell to less than a 1/2" away from the shock.I could be wrong though so if possible try them before you buy them.
That would be 3.6 cm, which equates to a little over 2" I think. They sure look like they've got a whole lot more than that inside! I thought they had more of an outside offset, than inside. Maybe they mean it's 3.6 cm offset to the inside? Still wont work, unless it's a reverse offset like most custom wheels.
A inside offset of around 2" on a 11" wheels means you will have 2" more inside. Half of 11" is 5.5", so you'd have another 3.6 cm (2") inside for a total of 7.5" aprox. inside. Not near enough clearance!
I've got 10" wheels, with 12" of tire, and my offset is a reverse, so it's 4" inside and 6" out. I just clear the shock and springs.
