wont rev over 5 grand
Old Jun 14, 2008 | 07:44 PM
73camaroSS's Avatar
Default RE: wont rev over 5 grand
1. timing is at number 8 on the timing mark,how do i check for chain play.
2.pump is good checked it out,new filter,how do i check the float.
Old Jun 14, 2008 | 07:52 PM
73camaroSS's Avatar
3.has cherry bomb mufflers with turn downs,has no cat,has a few crunches in the pipe but was there before this problem.
Old Jun 14, 2008 | 07:54 PM
73camaroSS's Avatar
4.car has self adjusting,how do i check for vavle floating.
Old Jun 14, 2008 | 07:57 PM
73camaroSS's Avatar
not sure on number 5 can you further explain that one.
sorry for all the post wont let me put that much
Old Jun 14, 2008 | 08:00 PM
Hollywood's Avatar
Was this problem there before or after you installed the tach
Old Jun 14, 2008 | 08:25 PM
73camaroSS's Avatar
the shakeing and lack of power at higher speeds and rpms was there before i put the tach in,did not know my car didnt rev over 5 grand intell i put the tach in.
Old Jun 14, 2008 | 08:32 PM
74454bb's Avatar
May 2007 ROTM
What size cam is in the car? Did you tune your car to get the best vacume?
Old Jun 14, 2008 | 08:58 PM
73camaroSS's Avatar
my dad told me a rv cam,not sure of the specs,motor was built like 15 years ago so all i know is what he tells me. what do you mean by best vacum.
Old Jun 14, 2008 | 09:08 PM
74454bb's Avatar
May 2007 ROTM
I had my timing set to 8 and 10, got a vac tester and followed the directions, car is about 28 deg timing and runs better then ever.
Old Jun 14, 2008 | 09:13 PM
  #20
74454bb's Avatar
May 2007 ROTM
also like said before..could be smaller heads. does it pick up if your secondaries kick in?
