wobbly door Window
wobbly door Window
My driver door window hasabout 1in or 2in of play in the window, like when i open the door the windowleans into the carand when i close the door the window gets pushed back out. So if any one knows what part i need to be looking for thanks for the help.
RE: wobbly door Window
If everything is right that shouldn't be hard, just pop off the door panel and make the needed adjustments. I just did it last night- its a little tricky, just play with the adjustments until you figure out how things need to be for it to be perfect. be very careful while taking off the panel and use the right tool.
Good Luck.
Good Luck.
make sure all the tracks are tight.their are 3 or 4 little felt lined fingers that are on top of the door frame,make sure they havent come loose.you might even need to adjust them
