Wiring diagram/code
Old Feb 28, 2022 | 03:39 PM
Mc83's Avatar
Default Wiring diagram/code
I have an 81 firebird and I'm working on fixing the hacked up wire from previous owners and I can't seem to find a diagram that would tell me what each color wire goes to from the firewall engine harness the picture I attached isn't of my car I just attached it so everyone will understand what I'm talking about I'd appreciate any help thanks
Old Mar 15, 2022 | 04:40 PM
DakotaZ28's Avatar
Hi, the bulkhead connector splits into 2 parts when you remove the centre bolt and pull it out. They kinda clip together to form a single plug that only goes together one way.
The one side has all the engine connections (engine harness) and the other (front end harness) has all the headlights, indicators, horn, etc.
Using the diagram below, you can work out where each one goes. That's what I did.
I also have a full wiring diagram that I will try post below this.
Old Mar 15, 2022 | 04:42 PM
DakotaZ28's Avatar
Wiring diagram attached
File Type: pdf
Alnowak7176
Feb 17, 2021 06:10 AM
87 camaro z28
Jan 22, 2013 03:56 PM
camaro89rs
Apr 14, 2008 05:16 PM
bill12690
Jul 11, 2007 11:06 PM
mongo
Dec 21, 2006 10:48 PM
