wiper question
Old Jul 14, 2007 | 03:46 PM
walsh4nd's Avatar
Default wiper question
i have a 79 camaro where the wipers died. I had them running to check that they were still working and as they were running they slowly died and stopped working...Should I probly replace the wiper motor or could it just be the wiper switch?? Also im havin some issues with getting my rear running lights to work...i checked all the fuses and bulbs, and all are fine...any advise would be great
Old Jul 26, 2007 | 01:50 PM
walsh4nd's Avatar
Default RE: wiper question
well after a few weeks ive had time to work on the car some more...still havin the same problems with the wiper motor and lights...any ideas???
Old Jul 26, 2007 | 02:58 PM
74454bb's Avatar
May 2007 ROTM
Check all the wires and clean all connections, You may have to replace some of the wires.
Old Jul 26, 2007 | 10:28 PM
thebandit110's Avatar
as for your back up lights...check your linkage that goes from the stearing wheel that goes to the tranny. that is tied in with your back up lights and your neutral safty switch
Old Jul 27, 2007 | 04:20 AM
jonjon's Avatar
October 2007 ROTM
I had the same problem, after days of looking for a back conection I decided replace the light bulbs and the one lighting the license plate was burned and it was making a false conection. After changing it everything when back to normal. So check the light bulbs if you have not done so.
Good luck...
Old Jul 27, 2007 | 09:14 AM
riceeater's Avatar
also, you could have a backfeed through the turn signal switch causing problems, when I got my car, the brake lights and taillights only worked when my blinker was on for a right turn. As for the wipers, sounds like the motor, def not the switch
lbx45
15
Oct 9, 2015 03:02 PM
v64thgen
Feb 24, 2015 12:07 AM
bennymanny
Apr 17, 2014 05:52 PM
mike6208
Jul 31, 2011 07:57 PM
brucehusker
Oct 20, 2007 08:42 AM
