will I pass a smog check in CA
Old 03-29-2008, 07:21 PM
mikemaccham's Avatar
Default will I pass a smog check in CA
Hey guys,
I am looking at buying a 77 Camaro, with a 350, manual trans.in CA. The seller has to get it smogged to sell it. When he went to get it smogged they told him it needed A air pump check vavle, erg valve, new exhaust and a cadalatic converter. (About $500 of stuff) I am getting a pretty good deal on the car ($1500 ) so my question is do you think it will be hard to get it to pass a smog check? Has anyone ever had a problem like this? Thanks
Old 03-30-2008, 12:00 AM
73 T Top's Avatar
Default RE: will I pass a smog check in CA
my truck wouldnt pass emissions so i put 2 new cats and new dual exhaust in it and it still didnt pass. ilive in oregon which has as tough or almost as tough emission laws. i ended up taking it to a shop and they leaned the carb out a bit and after i took the test they tuned the carb back up, it all cost me $30 and i passed the test with flying colors. It has a mildly built 350 with absolutely no (except cats) emission stuff on.
Old 04-01-2008, 02:44 PM
1980rscamaro619's Avatar
I live in San Diego CA and i bought my camaro for 1000, it needed a new exhaust and cats which ran aobut 800. After that it passed no problems. The exhaust you have is probably just rotted out and leaks the smog. After you fix those things it should pass. Make sure you have a proper aircleaner on it. It has to pass a visual check first. Good luck.
Old 04-01-2008, 04:29 PM
Make sure you give it a good tune up before the sniffer test. A poor running engine will fail, even with new cats. Also make sure the engine is fully warmed up and the cat lit up before testing, as cold cats do not burn smog.
Old 04-19-2008, 09:04 PM
Diablo87's Avatar
try pouring denatured alcohol in the gas tank prior to taking it to the smog place...pour about a gallon into a full tank of gas. what the alcohol does is burn off carbon. a friend of mine did that and he passed.
Old 04-20-2008, 04:28 PM
1977Camaro350's Avatar
Wow im glad we dont have emission checks where I live. My Camaro would never be able to pass.
mikemaccham
04-24-2008 10:49 PM
carkook
04-24-2008 10:55 AM
baabaa80
70-81 V8 Tech
03-05-2008 07:29 PM
rancho2940
08-05-2007 08:40 AM
BiG FriGG
06-13-2006 02:00 PM
Quick Reply: will I pass a smog check in CA
