HELP! I can't find the parts to pass smog!
Old Apr 8, 2008 | 05:59 PM
mikemaccham's Avatar
Default HELP! I can't find the parts to pass smog!
Hey guys,
So I bought a 77 Camaro with a 350 in it, it had washington plates and I live in CA. It has to pass smog, so along with getting new exhuast and a Cat conv. I have to track down some pieces before it can even pass the visual inspection.
Missing: 1 thermal vacuum switch (found that at pep boys)
2 "EFE " (ordered that through Chevy)
3" heat rise valve" that mounts to exhuast manifold...can't find it
4"theromostat air cleaner (aka: heat shield)...can't find it
. Any idea where I should look? Are these the correct names for the pieces? Also, is there a manual you guys would recomend for rebuilding a 77 Camaro that comes with a vacuum diagram? The smog guy said I won't need a smog pump, what do you guys think?
THANKS!
Old Apr 8, 2008 | 11:57 PM
1969 SS's Avatar
Default RE: HELP! I can't find the parts to pass smog!
buy a factory assembly manual and the diagrams will all be in there
Old Apr 24, 2008 | 10:49 PM
383 79's Avatar
Good luck. I lucked out, my 79 is old enough to not need to pass emissions Which is a good thing, because theres no way to make it pass.
etwilliamson
Aug 1, 2010 03:19 PM
ball81
Apr 3, 2010 04:48 PM
carkook
Apr 24, 2008 10:55 AM
mikemaccham
Apr 20, 2008 04:28 PM
97rsturbocamaro
Jan 12, 2008 10:11 PM
