what to do with exhaust
Old Aug 6, 2006 | 11:30 PM
69dmz's Avatar
Default what to do with exhaust
I bought the hooker headers and the flowmaster thunder series exhaust kit. should I dump them before the rear diff? or should I run the whole piping to the rear of the car. I haven't decided yet. Might see how it sounds when I install them.
Old Aug 9, 2006 | 01:58 AM
1969 Camaro's Avatar
Default RE: what to do with exhaust
i have a 69 as well, if i were you i would run them out the back because that looks good on a chevy and with your exhaust they should sound wicked too. if you run them down the side that more of a contemporary look and definetly not original for a camaro. my advice is to keep the car as much stock looking as possible.
Old Aug 10, 2006 | 12:50 AM
wizard148's Avatar
I have a 69 as well with 396. I am running hooker headers and Dynamax exhaust. I ran them out the back and I think that looks the best. Sounds good too.
[IMG]local://upfiles/4078/64898D639D25478297F785CDA4C9D3AC.jpg[/IMG]
Old Aug 10, 2006 | 02:06 AM
firebird69racer's Avatar
I would run them out back also. if you dump them in front of the rearend there is a chance of ex fumes intering the car
I have mine turn down just after the rear tire. the tip is kind of tucked up just above the bottom of the body so you cant see them
here is a pic that shows it the best, or not shows it as they are hidden but there are 3" pipes there
http://pg.photos.yahoo.com/ph/firebi...a2.jpg&.src=ph
if you like I might be able to get a pic of them from underneath
Old Sep 14, 2006 | 03:02 PM
1969 SS's Avatar
I have a 396 with Hookers. I have 3 1/2" collectors that go down to a 3" pipe, to Flowmasters and my exhaust turns down right after the rearend. man, what a sound!
granted my mill is built up pretty good also but I ALWAYS get compliments when I go to a show
Old Sep 28, 2006 | 11:45 PM
69dmz's Avatar
I dumped them at first. Sounded great, but damn the fumes from the exhaust. The next day I ran the exhaust out the back. It still sounds great and no more fumes. Now I'm changing out all the bushings when I get back from Iraq.
Old Sep 29, 2006 | 12:52 AM
74454bb's Avatar
May 2007 ROTM
Mine dump out just behind the seat for now, was gona dump them in front of the tires but Way too loud in the car at idle.dump them after the dif.
Old Sep 29, 2006 | 12:57 AM
uncle bill's Avatar
Install as large as a pipe as You can without dimpling the tubing. You need all mandrell bends. It makes it far less restrictive. Dump it out the back.
Old Sep 29, 2006 | 11:49 PM
69dmz's Avatar
Dumped them out the back just like when I got the car. Sounded awesome with dumped before the diff, but it sounds just as good with the exhaust all the way back.
scottlt194
May 14, 2009 08:27 PM
famlyguy18
May 6, 2009 05:26 PM
dbess23
Sep 17, 2007 02:02 AM
javione
Feb 16, 2007 02:27 AM
jhop16
Jan 9, 2007 11:21 AM
