A very odd electrical problem on a 1980 Camaro Berlinetta
Old Dec 6, 2020 | 04:38 PM
Jordan!'s Avatar
Exclamation A very odd electrical problem on a 1980 Camaro Berlinetta
I have a yellow 1980 Camaro Berlinetta with a 305 v8 power windows ac cruse control and delay wipers
For the the last month the voltage gauge has been reading almost nothing the oil lights on and the tachometer has been reading much higher rpms to the point of hitting it's limit.
iv replaced the gauge membrane alternator put a new battery ground wire on (made sure the small wire had a clean connection)
also cleaned 2 more ground wires on the engine bay fire wall.
I noticed if disconnect the plug to the cruse control relay the tachometer reads lower (still way to high)
fuel \ temp gauges still work lights work radio works brakes ect
not sure what's going on
help this is driving me nuts
Old Dec 6, 2020 | 09:39 PM
Zspoiler's Avatar
Have you start tracing wires for shorts?
Old Dec 6, 2020 | 10:16 PM
Jordan!'s Avatar
no I figured a bad ground non of the wiring seems to be messed with I just can't seem to locate where the ground is for the volt meter on the dash
95 camaro 406
Oct 8, 2015 02:49 PM
v64thgen
Mar 13, 2015 10:05 PM
Dave81Z
Jul 9, 2011 11:36 PM
ryan88z
Feb 28, 2010 03:48 PM
BANDIT59
Jun 24, 2007 10:39 PM
