un- known water pump make / spec
Old Jan 28, 2013 | 01:48 PM
stox58's Avatar
Default un- known water pump make / spec
Hi,
I brought a Big Block last year which i'm putting together. The water pump which is on it has ATF 30926 0402 stamped on it, but i can't find any information on it. Can anyone tell me where to find this info or if they know anything about them.
cheers from Luke
Old Feb 3, 2013 | 02:47 AM
stox58's Avatar
anyone know anything about ATF water pump? stock?, after market?
thanks
Old Feb 3, 2013 | 12:28 PM
Is it iron? If yes its probably stock or stock replacement. A pic would serve you better.
Old Feb 4, 2013 | 10:45 AM
Never heard of it, but over here it doesn't matter much, as Chevy water pumps are cheap. Is there some reason to worry about the water pump? Do you think it might be bad, or?
Old Feb 9, 2013 | 02:40 AM
stox58's Avatar
Yes it's made from iron.
So you think it's a stock replacement?
I don't think that it's faulty, just that i want to put this engine togther with good quality parts. So it performs well and is trouble free.
Old Feb 9, 2013 | 10:03 AM
Iron is most likely a stock replacement, and usually good if the pump hasn't been sitting so long the seals dried up. Since a water pump is so easy to change on the car, I'd try it and if it leaks, then change it.
Old Feb 9, 2013 | 10:13 AM
Edwardgp's Avatar
Just so the shaft where the fan bolts to isn't wobbling around I would give it a try.
doww301
Apr 4, 2011 02:49 PM
Lt1kidd
Dec 21, 2010 04:48 PM
Z28camaro94
May 22, 2010 03:47 AM
jbz28
Jan 27, 2008 07:57 AM
bluovlh8er
Jan 31, 2007 11:17 PM
