True 1980 Z28?
It's usually in the back of the backseat. You take out the back buckets by pushing them in enough for the mount to come loose, and there will be a bolt on each side of the lower backrest. Take the bolts all the way out, pull the bottom toward you just a little while also lifting upward. If the seats have never been out, it will take some work and seem like you're tearing something up, but it will be ok. The build sheet should be there if it's how I describe. If the seat back just pops out when you lift it, you're probably out of luck. But look in the springs anyway.
You might get lucky with a build sheet, you might not. There was no set rule for the build sheet to stay with the car once it was completed. The line workers at the end needed to get rid of the sheet, so they either stuffed it inside the car, or threw it in the trash.
New to this so I hope I have this right.
Hello, I'm new to this - so bear with me please. I have a 1980 Camaro and kind of know what I have but need some guidance. I'm not a fool to cars. If someone can take the time out to tell me what I have for sure please.
