transmissions
Old Jul 23, 2006 | 08:11 PM
80z/28's Avatar
Default transmissions
Hi everybody, As anyone replaced there turbo 350 trans with a 700r4 trans in a 1980 camaro z28 thanks!!
Old Jul 23, 2006 | 09:27 PM
SickSickSick's Avatar
Default RE: transmissions
can be done with some alterations to the crossmember and hotwiring the lockup solenoid. you can run a 700R-4 without the lockup engaged but they shift REALLY hard without it. i use one in drag racing and the hard shifting actually helps but, it would be unpractical for street use. it only shifts under high rpm loads. why are you looking to change? you have a better tanny with the 350 just isn't as good on gas mileage. sick
Old Jul 23, 2006 | 10:04 PM
80z/28's Avatar
what about changing the rear end, putting a higher gear in the rear end?
305_camaro
Mar 27, 2021 08:01 PM
iCrossbone
Mar 28, 2011 06:23 AM
husker_camaro95
Jul 4, 2010 11:52 PM
crazycar350
Oct 8, 2009 09:38 PM
n8sz28
Aug 28, 2005 03:25 PM
