trans Crossmember issues
Old Sep 23, 2009 | 01:29 AM
RonRico's Avatar
Default trans Crossmember issues
Needs some help here. Im putting a 350 ci and a TH350 into my 1970 that came with a standard trans. When I went to bolt on the transmision the crossmember does not line up with the holes in the sub frame they need to be about 10 inches closer to the front. Even more so the crossmember cant fit that close between the body and frame. Is there a differance where a standard and auto trans mount. Help
Old Sep 23, 2009 | 10:55 PM
There is a difference in where they mount, but the same crossmember is used in both. I believe there are another set of holes for both positions. Been awhile since I've been under mine, but I seem to remember this.
Old Sep 25, 2009 | 03:24 AM
countryboy400e's Avatar
I have a question on the same thing with the crossmember. I need to know if the crossmember is the same for a th350 and a th400.
Old Sep 25, 2009 | 05:09 PM
Same crossmember, different location.
Old Sep 25, 2009 | 06:05 PM
RonRico's Avatar
Yeah I had to drill through the frame and line up the crossmember closer to the mount on the TH350. No fun!! But its done. I had to losen the sub frame from the body to move it forward. I wish I would have thought about this befor i started banging on it to move it forward.
Old Sep 25, 2009 | 06:56 PM
bowtieguy's Avatar
July 2009 ROTM
same just move it back
Old Sep 26, 2009 | 12:58 AM
ok thanks for the help
BostonShawn
Jan 12, 2015 09:50 AM
WIspartan1026
Jul 10, 2011 09:19 PM
andyracer125
Dec 30, 2008 03:54 PM
kmand83
67-69 V8 Tech
Oct 23, 2007 05:32 PM
94Z28SHAKER
Jun 20, 2006 03:17 PM
