tire size for a 1970 Z28
Old Feb 24, 2007 | 12:05 AM
ChevyMan 427's Avatar
Default tire size for a 1970 Z28
i want to put 17" rimsin the rear.what is the biggest and widest size tire that i can fit in the rear of my 1970 camaro.
Old Feb 24, 2007 | 12:15 AM
74454bb's Avatar
May 2007 ROTM
Default RE: tire size for a 1970 Z28
Pretty big,I've seen guys with 275/60/15's on the back and those are 28"OD and about 10" wide. with 17 inch rims you should have no problem puttin on 275/40/17 with an OD of about 25.7 .......................but check around first.
Old Feb 24, 2007 | 12:24 AM
what if i keep the 16 inch rims how big of a tire could i put
Old Feb 24, 2007 | 12:30 AM
74454bb's Avatar
May 2007 ROTM
The largest tire I've seen in 16 is a bf goodrich g force ta drag r at 255/50/16. The rest are 245/50 's. Do you know how tire sizing works?
Old Feb 24, 2007 | 10:07 PM
JRs72RS's Avatar
February 2009 ROTM
Make sure to do your homework. Check the room in the wheel well for backspacing. The limiting factor is the width of the wheel house. ten inch is about the max and still retain suspension travel for a good ride. Of course if you wish you can install mini-tubs, plenty of room then.
Old Feb 24, 2007 | 10:30 PM
74454bb's Avatar
May 2007 ROTM
I would say nothing more then 4" of backspace. And if you don,t know what any of this is then let us know so we can tell you.
Old Feb 25, 2007 | 07:47 PM
Iknow how tire size works but i am not sure what i want to do. i am just trying to get some ideas.
Old Feb 25, 2007 | 07:50 PM
74454bb's Avatar
May 2007 ROTM
ok,don't worry as soon as you figure it out and get the ones you want on the car......you'll change your mind.
Tpls6Tate
Dec 12, 2012 08:16 PM
ZL1
Nov 4, 2011 04:41 PM
camaro_junky24
Mar 16, 2010 05:53 PM
bd92rs
Aug 7, 2009 09:04 PM
ugly88gt
Feb 24, 2009 07:25 PM
