Tire problems
Old Sep 29, 2009 | 08:22 PM
tbl76camaro's Avatar
Default Tire problems
My front left tire sticks out further than the right, WHY? It scrubs when I hit a little bump on the road or if I turn right and tired of it doin that. Please help
Old Sep 29, 2009 | 08:33 PM
machine1999z28's Avatar
sounds like you got suspension troubles brother. Better get that thing up and see what wiggles
Old Sep 29, 2009 | 08:38 PM
Hard to say. Could be a few things that could cause the tires stance to be off. If the car has been in a front end accident, that could have moved the subframe slightly. Remember if it shifts just 1/4" to one side, it will result in a 1/2" change on the opposite side.
You could also check your wheels to be sure they both have the same offset. Check the inner fenderwells also, to see that they fit the frame the same on both sides, which might reveal where the problem is.
mp734
Nov 6, 2013 11:54 AM
fearbunny
Jan 18, 2010 07:59 PM
IZZY1967RS
Jun 19, 2008 10:29 PM
jdubs1813
Nov 12, 2007 04:16 PM
o2camaross
LS Series Tech
Feb 24, 2007 02:09 AM
