Throttle Kickdown Linkage
Old Nov 15, 2012 | 02:38 PM
Tomg303's Avatar
Default Throttle Kickdown Linkage
Okay so my camaro isn't shifting so I decided to adjust my kick down linkage. I unlock it and WOT the carb relock it. Now the question is should the linkage have some tension on it? It doesn't return after the throttle has been opened. Is there only tension when the car is running caused by vacuum. Idk i'm lost.
Old Nov 15, 2012 | 03:45 PM
The cable is pulling on the detent valve in the trans. The valve is spring loaded and should pull the cable back when the cable is released. Sounds like the valve is stuck in the pulled out position, or the cable is kinked and stuck, which could explain why the trans isn't upshifting (valve stuck in downshift mode).
Old Nov 15, 2012 | 10:48 PM
Tomg303's Avatar
Alright now that I understand how it works I should be able to figure it out
frank t
Apr 14, 2015 11:25 AM
goodbuck
Oct 22, 2010 07:37 AM
n269nando
Jun 28, 2010 06:58 PM
Moe Watts
Aug 17, 2009 10:27 AM
bdam0214
67-69 V8 Tech
Oct 31, 2007 03:40 PM
