Sway Bar Bracket Screw Thread Tap
Old 05-30-2010, 01:16 PM
ATM's Avatar
ATM
ATM is offline
Originally Posted by 77nomad
Just do one side at a time and you'll have a referance. The axle on my new car has nothing, and I haven't done drums in a few years now so it will be a task for sure. Am considerind a s10 rear disc swap though. That doesn't look hard at all.
I've read about it, maybe once I get the car done I can make it a winter project. Seems like the proportioning valve really throws a wrench in things though.
Old 05-30-2010, 06:30 PM
Yeah, I get to start with a fresh body at least I don't have to get a old nasty prop out. There are at least 5 junk yards here in town. I know i can score the parts fairly cheap.
Old 05-30-2010, 07:56 PM
rosky69's Avatar
I'm going to a rear disk set up eventually. I am just trying to get my engine back from the machine shop so I can drop it and the tranny in. I really just want to drive my camaro!
Old 05-30-2010, 10:04 PM
Discs are definitely much easier to change pads on than shoes on drum brakes, but I'm sure your talents will get you through a brake job. What I've seen you tackle so far on your Camaro project shows me you've got well above average mechanical skills, and you're not afraid of trying new tasks.
I hate doing drum brakes, but I still do what 77Nomad suggested and do one side at a time, so I wont screw them up. I did discs on all 4 wheels of my daughter's Mazda Protege Sat., and took all of 90 minutes to complete. That's probably the only reason I'd ever go to discs on the rear; to make it easier to change. But since I only get about 2,000 miles a year on the Camaro, they last a long time!
Old 06-01-2010, 10:26 PM
Z22man's Avatar
any ideas where i can get the sway bar arms the mount from the from brackets to the bar?
Old 06-02-2010, 07:00 AM
Me. The bar from the upper mount to the sway bar right? 25 bucks plus the ride.
87 camaro z28
01-31-2013 10:46 AM
69camaro1
11-10-2006 04:30 PM
350rs
09-21-2006 06:33 PM
Quick Reply: Sway Bar Bracket Screw Thread Tap
