stereo wont remember preset stations and settings
Old May 16, 2009 | 02:48 PM
jason7504's Avatar
Default stereo wont remember preset stations and settings
my stereo doesnt remember my preset radio stations or any of my settings once i turn the car off ACC. what could be causing this and how do i fix it?
Old May 16, 2009 | 02:58 PM
Did you just install it? is it aftermarket? Most stereo that have presets require two power supplies. One with the key on and the other is hot all the time. Sound like your power wire that should be hot all the time is hot only with the key on.
Old May 16, 2009 | 03:13 PM
jason7504's Avatar
yeah i installed it yesterday. yeah its a panasonic. how would i have 2 power supplies? well i connected both the power and ACC cable to the battery.
Old May 16, 2009 | 05:27 PM
If you hook both to the battery the stereo would be on all the time regardless of the key. You hooked both wires to the Key on/off side of the fuse box. Leave the main power wire where it is and hook the acc wire to a power source that is on all the time like the acc fuse. I am sure this is covered in the install instruction.
Old May 16, 2009 | 05:33 PM
jason7504's Avatar
well i have an 81 camaro and i dont know where the acc fuse is and how to hook it up. it doesn't really tell you that in the instructions
Old May 16, 2009 | 06:44 PM
Just keep pulling fuses untill your dome light goes out. That is the fuse you want. If you have a test light you can just hook it to ground and look for power with the key off.
There is no way the stereo Manufacture can list instruction for every model every year. Since most car made after 1982 have a full time power wire going to them this is not an issue for 99.9% of the installs.
Old May 16, 2009 | 07:02 PM
jason7504's Avatar
my dome light doesn't work...i didnt wire my car, the person before me did and he didnt do a good job. so im not sure what wires to use and what fuse to look for?
Old May 16, 2009 | 08:34 PM
Did you try the test light like I said? I have no luck on this site talking people thru electrical issues.
If your car is not work as it did from the factory and you do not have basic electrical skills I do not see how I can help you. There is no way for me to know what has been changed in you wiring.
Old May 17, 2009 | 01:19 AM
You can splice power off your cigarette lighter wire. Those had full time power in earlier cars.
Old May 17, 2009 | 01:55 AM
jason7504's Avatar
my lighter doesn't work though..
