Steering Column Re-assembly Tool
Old May 14, 2021 | 05:16 PM
Phlash56's Avatar
Default Steering Column Re-assembly Tool
Hello,
I am attempting re-assembly of the steering column on a 1970 Z28 to replace the ignition key cylinder and turn signal switch. The Haynes manual shows that "a special U-shaped tool which fits on the shaft should be used to depress the lock plate" in order to install a snap ring. Does anybody know what this U-shaped tool looks like or where I might find one?
Any info would be appreciated.
Thanks
Phlash56
Old May 15, 2021 | 08:43 AM
Zspoiler's Avatar
Sometimes you have to "think outside the box" and make your own.
Old May 16, 2021 | 06:52 PM
Just search for "Steering Wheel lock Plate Remover" Most parts stores will have them, many have them as a loan a tool program. Harbor freight, Amazon, Walmart online.
Old May 17, 2021 | 01:18 PM
Phlash56's Avatar
Thanks! Found one at O-Reilly. Didn't know what the name of that was!
bruce69camaro
Jan 28, 2019 11:26 AM
Kathy A Chism
May 8, 2017 09:17 AM
MJTate
Jun 25, 2013 06:26 PM
hottroddin
Mar 8, 2012 08:05 PM
ccdalamp
May 22, 2006 01:18 AM
