Speedometer cable question, electronic to mechanical?
Old 12-18-2011, 08:20 PM
Thats the inside end right? That goes into the speedo with a clip. Then the nut on the other end that everyone described.
Old 12-18-2011, 08:23 PM
klong2194's Avatar
that is whats under my dash, the nut that everyones talking about idk where that is, havnt looked
Old 12-18-2011, 08:24 PM
klong2194's Avatar
but yes it clips in the speedo not threads on. does the original one clip in?
Old 12-18-2011, 08:29 PM
The nut is down at the tranny side.
Old 12-18-2011, 08:33 PM
klong2194's Avatar
whats that nut have to do with anything?
Old 12-18-2011, 09:33 PM
It holds the cable into the transmission. If the tranny doesn't have that you'll need to find a adapter to cange the VSS signal to a rotational drive for the speedo. None of it has anything to do with the gauges.
Old 12-19-2011, 10:23 AM
I think what got thi confusion started is you were talking about your mechanical cable not working with the electronic speedo output on the trans. Then you showed us a pic of the cable end, and we thought you were showing us what you were talking about. Is there a reason the speedo end is off, or was it already off when you got it?
The speedo end on later 2nd gens is a clip held, while my '71 screws on to the speedo and the trans.
Old 12-19-2011, 02:31 PM
rydeer's Avatar
I may still be confused but, My car is a 76. Here is a pic of the back of my dash. My finger on the clip thing and my cable. I can't get to the tranny end of the cable now. It is a 350 and screws on.
Hope this helps
Attached Thumbnails Speedometer cable question, electronic to mechanical?-001.jpg   Speedometer cable question, electronic to mechanical?-002.jpg   Speedometer cable question, electronic to mechanical?-003.jpg
Old 12-19-2011, 02:52 PM
Hope this helps
I'm confused too now! You have a clip and threads? I don't see any threads anywhere on that speedo? Looks like it's a straight clip on to me?
  #20
Old 12-19-2011, 03:27 PM
rydeer's Avatar
The tranny end has the slip nut that screws it. Sorry for the confusion.
Are We anywhere near his orig. question.
Quick Reply: Speedometer cable question, electronic to mechanical?
