spectre cold air intake for 2nd gen camaro's
Old Nov 1, 2009 | 12:03 AM
jason7504's Avatar
Default spectre cold air intake for 2nd gen camaro's
has anybody used the spectre dual cold air intake for carberated engines. they have some that are specifically made for 2nd gen camaro's for like $500 and then they have like universal kits for like 200(as seen below)
http://www.jegs.com/p/Spectre/Spectr...69283/10002/-1
i didn't think they made cold air intakes for 2nd gens or any carberated engine. do you think there worth getting for the money? and how much hp do you think they would give? 25hp?
Old Nov 1, 2009 | 10:03 AM
Waste of time and money. Cold air intakes on a carbureted car wont even give enough HP increase to feel a difference. Might get 5 hp at most.
Since you've got a cowl hood now, your best bet is to get (or make) a seal that will seal your air cleaner to the cowl intake. That will be cheaper and do much more than the expensive system.
I built mine from two air cleaner for under $40. Bought the largest base I could get, then put a smaller element and top from 2nd air cleaner on top. Went to a foam rubber supplier and had him cut me a strip of dense foam that was 1" thick and long enough to fit the circumference of the base cleaner. Then I just used contact cement to glue the strip to the base, and back to itself in a circle.
I put a straight edge across thw fenders and measured the distance to the base to get the measurement for the width of the foam to have it cut. Now when the hood closes it seals against the inside and I get nothing but cold air in.
Old Nov 1, 2009 | 07:26 PM
jason7504's Avatar
how big is your base?
my element is 14" across
Old Nov 1, 2009 | 07:39 PM
Base size depends on what size your hood opening is. You'll need a base that's equal to, or larger than your opening. Also need to be sure that the opening is centered over the carb, or an offset base will be required.
A custom base can easily be made from sheet aluminum and tin snips. Just cut a circle the size you need, then cut a hole the size of your existing air cleaner. Then situate your element on the top and your old top on that. Then the foam can be glued to the custom base.
gwpotter
2010+ V8 Tech
Nov 15, 2011 08:54 AM
lt4weeda
Feb 8, 2009 02:43 PM
Celticsfan
Jun 4, 2006 11:39 PM
