Small block Question
Old May 10, 2020 | 01:06 PM
Angrymike's Avatar
Default Small block Question
My buddy has a 90's small block out of a truck that were thinking about putting in his Monte Carlo. I have a set of old 60's 194 heads. The compression is 9.4 with the truck heads, they're 193 heads, what would the comp be with the old fuelie's ? The old heads are 461's. How do you think they'll work with a decent cam ? I'm a big block guy, so I no little of small blocks, thanks.
Old May 10, 2020 | 05:19 PM
Everett#2390's Avatar
Search for 193 volume and compare as 461's are 63 cc's and go from there. More than likely, the 193 will be a larger volume thus a lower static compression ratio.
Use arithmetic and figure out the static compression ratio. Head gasket figure on .025" height, piston head is .025" down figure volume with stroke vs. diameter, convert to CC's, and go from there.
Old May 10, 2020 | 09:29 PM
Angrymike's Avatar
I actually did that with my big block and it came out almost exact, thanks will do.
Angrymike
Oct 4, 2019 03:31 PM
69camaroaddict
Oct 3, 2009 08:54 PM
stuccoman
May 11, 2008 10:52 PM
RcrX
Sep 25, 2007 07:20 PM
15_lt_15
Jun 7, 2006 08:42 AM
