siezed up bolts, what to do?
Old Aug 5, 2008 | 04:39 PM
Latinoeheat's Avatar
Default siezed up bolts, what to do?
Im replacing the alternator cover on my 78 Z28 but there are two bolts that I just can't get to budge. I've tride using "Liquid Wrench" but it didnt work at all. Hints, ideas?
Old Aug 5, 2008 | 05:04 PM
Default RE: siezed up bolts, what to do?
I presume you're talking about the long bolts that hold the case halves together? A little bit of heat with a propane torch should do it, but don't over do it and cook something you shouldn't. Sometimes, the end of the bolts stick out, and you can touch a chunk of dry ice on the bolt to shrink it and break it free. You might be able to get some dry ice from your local Baskin Robbins ice cream store. And remember not to touch it with your bare hands!!!
Old Aug 19, 2008 | 12:47 PM
lowmileage's Avatar
You might as well pour water over it than using LR. PB blaster is much better but if it's really bad, use it daily for a week before attempting to get the nut off.
78stroker
Apr 12, 2013 09:33 PM
endo
Sep 19, 2010 11:25 PM
wiskow
Mar 9, 2010 08:23 AM
vinnyboombots
Mar 28, 2009 10:53 PM
awake1630
Apr 2, 2008 11:04 AM
