Sander
Old Nov 12, 2006 | 04:20 PM
CCarRocks's Avatar
Default Sander
Can anyone tell me where to get a 700-100 RPM electric dual action disk sander? Air is not an option for me is the resaon I need electric.
Also would a good palm sander and belt sander work as back up for tight places?
As you can guess I'm getting into th sanding and body work on my ride.
Thanks for the links and info.
C Car
Old Nov 12, 2006 | 11:09 PM
shnormo's Avatar
Default RE: Sander
It goes in a semi circular motion and it also goes vertically and horizontally. It doesn't keep the sanding pad consistently in one place. Belt sander works for large space, but it does tend to heat the metal. Http://www.harborfreight.com will prolly have the tools you're looking for.
Old Nov 13, 2006 | 09:27 PM
uncle bill's Avatar
Default RE: Sander
When You use an orbital sander, it's designed to work so You don't wear one spot. It makes for a better overall finish.
