rookie electrical question
Old Apr 10, 2013 | 05:37 PM
FnNewGuy's Avatar
Default rookie electrical question
This is a side note from my other thread.
Why does the wiring diagram show two grounds coming off the neg batt terminal? And where are they supposed to go? (on for engine one for frame?)
Also it appears that one of my ground wires has been cut (the smaller one). I never noticed it before. Unless there are two wires running in side the protective sleeve on the one wire coming off the neg terminal
Old Apr 10, 2013 | 08:20 PM
Everett#2390's Avatar
The smaller gauge wire is bolted to the fender in assisting ground return from the body.
Old Apr 11, 2013 | 07:22 AM
FnNewGuy's Avatar
if I don't have that smaller wire grounding to the frame do you know wha tissues I may see going on off hand? It looks as though mine was cut and never replaced.
Old Apr 11, 2013 | 09:15 AM
Without the body ground you could have an incomplete circuit, or a low voltage situation from high resistance condition. Better replace the ground before you do any troubleshooting or your efforts will be in vane.
Old Apr 11, 2013 | 11:30 AM
FnNewGuy's Avatar
thanks. I am definitely going to replace. Now is that an actual fusible link with the thicker insulation wire? Or is it just a regular smaller wire for that link to the frame?
Also, the car has been this way for as long as I've had it, I've never noticed it until now. The reaosn I was asking what issues I might see is because I haven't really seen any.
Old Apr 11, 2013 | 12:05 PM
The fusible links are inline with the positive supply wires, not the ground. I like using a 10 ga. wire for the body grounds. If it's easier for you, you can connect that wire to the same place on the engine block where you have the negative battery ground cable, and jump it to the firewall to a good clean spot.
Old Apr 21, 2013 | 11:27 PM
millpondmonster's Avatar
you can't have to many grounds. body to the frame, engine to frame, engine to body at least one of each but more is better. It will help with a number of things.
63StingRay
67-69 I6 Tech
Jan 29, 2013 03:48 PM
Kraker
Oct 15, 2012 10:22 PM
JackBlack95
Nov 15, 2011 07:48 AM
strokerracing
Aug 30, 2011 05:07 PM
Greaser513
82-92 V8 Tech
Nov 21, 2007 02:00 PM
