Rims...what tires?
Old Oct 21, 2008 | 05:34 PM
jakel's Avatar
Default Rims...what tires?
Hello all, I am new to the camaro scene. I have a 81' berlinetta with stock wheels, however my uncle a chevy guy has a set of two 14x7 torq thrusts (front) and two 15x8 torq thrusts (back) that he is going to give me to freshin up the look. My question is what size tires would look good on these wheels with my car...thanks alot[/align]
Old Oct 21, 2008 | 09:49 PM
kyphur's Avatar
Default RE: Rims...what tires?
On my rear 15x7's I have 255/60/15's and on my front I have one size up from stock (235/60/15) and have no problem with rubbing. I think I could get away with a bit bigger in the back but I like the way the 255's look. I think you might also want to know what the backspacing on the new rims would be also to make sure you have clearance.
You can use this calculator to figure up tire sizes. Yeah, I'll probably catch hell for it being a mazda miata site but it's pretty helpful, ha ha. You can visually compare two different tire width and radius on there, just click on the radial button that says, "end" instead of "side". I know that's a gimme, but I didn't see it till the third or fourth time I used the site.
Old Oct 21, 2008 | 11:34 PM
jakel's Avatar
kryphur that is a very helpful site to give a rough estimate of tire size thanks! I know the backspacing on each wheel is 4.5" both the 14" and 15".
Old Oct 22, 2008 | 12:52 AM
73camaroSS's Avatar
https://camaroforums.com/m_244796/tm.htmthese are my new rims they rub in the front a little, but you should make sure you put BFGoodrich Radial T/A's with the white letters out for the cool old school look,post up pics when you put them on.
Old Oct 22, 2008 | 05:55 PM
jakel's Avatar
73camaross: Those rims and tires look pretty sick, what is the backspacing on them? I've been reading through other posts and is 4.5" backspacing going to be too much? Everyone seems to be running 3.75" or 4".
Old Oct 22, 2008 | 06:15 PM
73camaroSS's Avatar
there stock camaro back spacing you should beable to fit 235 in the front with 7 inch rims and 8 inch in the rear,if you are going for the in the wheel well look the bigest i would go is 265 maybe a 275 will fit and if your going for the air shock look you should beable to fit a 295/50/15 in the back. oh and thanks for the complimant on my rims the cost me a pretty penny. i got them from stocktonwheels.com.
jackss00
Feb 22, 2012 02:21 PM
luciora
Apr 14, 2010 06:36 PM
Adam78
Jan 27, 2010 03:38 AM
fatty2828
Aug 6, 2007 01:13 PM
hermanus
Apr 6, 2006 07:26 PM
