rebuild carb on 77 after sitting up for 1-2 years
Old Nov 8, 2009 | 09:05 PM
Actually, having the timing too far advanced can be more evident with a hot engine versus a cold engine. Fuel is more apt to pre-detonate on a hot engine, which then tries to kick the pistons back down before they get to the top. Still not sure from your description if you're having a slow cranking or no cranking problem? If your engine is going rump-rump-rump as you crank it (insert jokes here), then adjust the timing to be less advanced. But if you're just getting a "click" when hot, it's more than likely a starter heat soak problem.
Old Nov 8, 2009 | 09:54 PM
ROWDYROB's Avatar
hey---thanks for the replies,i must of had a brainfart,the ground used to be connected to the alternator bracket ,but during all the changing i put a new chrome one on with differant bracing and then moved the wire---just forgot---i was looking at running it back to the top of the aluminum intake---you think that will be good enough--thanks
Old Nov 8, 2009 | 11:01 PM
ROWDYROB's Avatar
i should put up some pictures--would blow your mind,i changed the front end to a 70-73 and also cut the quarters and the whole rear and changed it to a 70-73----painted it with baldwin motion stripes---looks just like a 70-73 except for the wrap around back windshield that didnt come out till 75---had a die hard old car guy think that i actually took a 70-73 body and cut a wrap around back windshield in--lol
Old Nov 9, 2009 | 06:13 PM
ROWDYROB's Avatar
CHANGED the battery cable to the engine and it solved that problem---thanks
Old Nov 9, 2009 | 06:32 PM
That's great news! Glad you got it going!
Old Nov 9, 2009 | 08:26 PM
Y2K's Avatar
Y2K
NickCopelin
Jun 5, 2012 09:30 PM
druggist81
Jun 3, 2012 01:59 PM
dogdog130
Aug 19, 2011 09:15 PM
MARO Z86
82-92 V8 Tech
21
Oct 25, 2008 12:57 PM
kelsroc
Mar 30, 2007 08:44 PM
