rearend problems
well first of all this question belongs in the 2nd gen section so we will move you there were you should get some help. maybe read the rules when you need to go to sleep sometime. thanks and welcome to the forum. enjoy.
Can I assume you're trying to disassemble the rear? The next step after pulling the screw and pin from the rear carrier is to make sure you remove the wheels and the drums, then push in on the axles to remove the C clips. Once the clips are removed, then simply pull the axles out and you're ready to remove the guts of the carrier, or the posi springs, plates, and clutches.
