Rear end issue
Old Sep 17, 2009 | 04:37 PM
wrwest73's Avatar
Angry Rear end issue
I have a 73 camaro that after installing 15x10 centerlines with 4 7/8 back space will hit the right rear fender lip on a hard launch. Bending the lip will not fix this much of a differance. I have measured both sides of the car and the right rear wheel is about 3/4" further out than the left one. I have since noticed that all the second gen's I have seen have this same issue. Does anyone know how to fix it?
Old Sep 17, 2009 | 06:37 PM
You could install a spacer on the left side to make them equal, but moving the axle mounts would be the only way to make the difference up. That could be a pretty good weekend project if you've got a welder and torch.
PS- I just measured my 1971 and the rear axle is perfectly centered.
Old Sep 17, 2009 | 08:27 PM
You might have worn out and collapsed leaf spring bushings which could be allowing it to sway that way.
cvsisinthehouse
Oct 17, 2014 09:53 PM
dtkarst
Nov 25, 2013 10:19 PM
jb9513
Oct 16, 2013 04:08 PM
KcLive
Mar 19, 2010 09:45 AM
steve1967
Oct 6, 2007 11:06 AM
