rear end?
Old Mar 26, 2006 | 05:03 PM
speedy9220's Avatar
Default rear end?
i got a 1980 camaro which had a v6 when it was new. i just bought it from a guy that put a 327 in it. here is the problem - it has no *****. the motor runs awsome but doesnt want to get up and go. could it be the rear end? i believe its the stock one that came in it. its got a t350 trani. it will peel out goin backwards but not forwards. thanks for the help in advance.
Old Mar 26, 2006 | 10:44 PM
v8chvyguy's Avatar
Default RE: rear end?
If it had a V6 in it then it more than likely has 2.54's or 2.73 in the rear. When you're doin 60 and punch it dose it take off like a raped ape?
Old Mar 26, 2006 | 11:09 PM
speedy9220's Avatar
it takes off at sixty pretty good. do you think if i changed the rear end to the right setup and/or possi, it would fix my problem?
Old Mar 27, 2006 | 09:52 PM
v8chvyguy's Avatar
If it's an anorexic gear issue then it definately will. Make sure you know for a fact what gears you actualy have. If you have anything higher than 3.08's(the lower the # the the higher the gear) definately consider a gear change. I have 3.08's in my 79 4 spd. Z28. and they drive great and give me decent gas mileage. I don't plan on changing from that until I get the five speed then I may goto 3.42's or back to the 3.73's I origionaly had.
Old Mar 28, 2006 | 12:51 AM
bowtieguy's Avatar
July 2009 ROTM
if you get under the car on the passenger-side,on the front side of the axle-tube,use a wire brush and you should find the rearend id number.you can call chevrolet and they will tell you what you have(if the gears havent been changed)or if you have a haynes book ,they have all the numbers in the rearend section.you can also look on the ring gear and find what ratio you have
Old Mar 29, 2006 | 12:50 AM
v8chvyguy's Avatar
We always pull the cover. Read the number on the ring gear. sometimes the rear ends were not geared the way they were numbered. Always pull the cover.
Old Apr 4, 2006 | 03:29 PM
shnormo's Avatar
Something that could help is getting the carb tuned, new spark plugs, wires, cap and rotor, a transflush and rear diff flush. Clean off the carb butterfly.
Saaampson74
Oct 20, 2008 04:56 PM
libertyforall1776
Nov 10, 2007 03:04 PM
