rear end
Old 08-31-2008, 06:55 AM
speedy9220's Avatar
Default rear end
will a posi out of a 87 monte carlo ss fit into a 80 camaro without a problem?
Old 08-31-2008, 06:40 PM
Default RE: rear end
No they are not interchangeable. The 80 Camaro is a 28 spline differential & the 87 Monte Carlo is a 26 spline differential.
Old 08-31-2008, 07:37 PM
screamineagle's Avatar
Not only are they different spline but also im almost positive the 87 monte carlo has the 10 bolt 7.5 ring and pinion. The 80 camaro has a 10 bolt but the ring and pinion is 8.5 so it won't fit.
Old 08-31-2008, 08:36 PM
bowtieguy's Avatar
July 2009 ROTM
the monte carlo is a coil spring car where as the camaro is a leaf spring car.you can make it work but it would be alot of work.change all the mounting brackets,shock mounts .
Old 08-31-2008, 08:39 PM
bowtieguy's Avatar
July 2009 ROTM
the parts are not interchangeable
Saaampson74
10-20-2008 04:56 PM
libertyforall1776
11-10-2007 03:04 PM
Quick Reply: rear end
