rear axel noise
rear axel noise
the other day i noticed for the first time a wierd noise when i make hard tunrs. i thought it was the exhaust rubbing the tire when i went into the turn hard. but i looked and shook the car and the exhaust does not hit it. you can feel it in the tire when it makes the noise. its like a flapping noise. i have no idea and i hope i didnt destroy my axel...anyone have any ideas???
RE: rear axel noise
how do i check if the axel is hitting the the thinger, i poped the wheels off and it does move like a really tiny amount. both sides do it. but its so small it barly moves. but when the noise happens. you feel it!
RE: rear axel noise
it could be also the brake shoes could be loose and could be slapping and the hubs. or maybe a bracket broke or a shock let loose or a coil spring broke or the rear swaybar broke.**** dude i cant think of anything else.
RE: rear axel noise
If it dose not affect the car, then drive it till it gets worse. It's hard to diagnose a flapping nois over the internet. My only suggestion is the same as 80's, pull the cover and look for metal.
