question????????
Old Apr 7, 2006 | 03:43 AM
dansmith692003's Avatar
Default question????????
i have a 1980 camaro 3.8 v6. i have a 350 motor to put in but i dont know if it will be possible. my question is that what do i need to do? the tranny is a 350so i would think that would work but i dont know. can u all help me? will it all bolt up ?
Old Apr 7, 2006 | 09:13 AM
mike86rs's Avatar
Default RE: question????????
for the most part everything should bolt in, the only thing you might have to change is the motor mounts.
Old Apr 8, 2006 | 03:05 AM
v8chvyguy's Avatar
Check the bell housing some of the 3.8's had a BOP (Buick, Olds, Pontiac) bolt pattern. A 350 Chevy will not bolt up, but a 350 Olds will. You may be changing trannies and a driveshaft. Are you sure that trans ain't a 200 metric? the pans look the same and thats usually what went behind the V6's.
Old Apr 11, 2006 | 05:12 PM
damn u were right. bolt pattern is different. u know anyone that wants a 350 engine with 350hp?
JPrice
May 20, 2012 03:48 PM
endo
Sep 30, 2010 12:51 AM
josh75camaro
Jan 7, 2010 09:09 PM
