Quadrajet 4MV Choke Problem
Old May 4, 2011 | 08:14 PM
lobby350's Avatar
Default Quadrajet 4MV Choke Problem
So I have an '81 camaro with a 350 crate motor and a Quadrajet 4MV that doesnt like to run when the engine is cold and the tempature is below 60 out. If I start the car it doesn't idle high like it should, it idles real low and feels like it'll load up and die eventually. To keep it running i keep my foot on the pedal a little bit and it blubbers and misses, but stays running. Once the temp gauge hits about 130 degrees the car smooths out and runs perfect. What do you think is the problem? And what would i adjust on the choke to fix my issue here? thanks
Old May 4, 2011 | 09:08 PM
80ZJoe's Avatar
July 2010 ROTM
sounds like the choke isn't working at all. What helps for cold starts is opening the intake ports, take off the port plugs (flat metal things you get with the gasket sets) so the carb heats up quicker, but check and see if you have power to the choke anyway.
joe
Old May 4, 2011 | 09:15 PM
Here's everything you need to adjust theQ jet:
Rochester Quadrajet Tech Info - The Carburetor Doctor
Old May 4, 2011 | 09:24 PM
80ZJoe's Avatar
July 2010 ROTM
thanks Val
Old May 4, 2011 | 09:27 PM
Hope it helps you get your's running Joe!
Old May 5, 2011 | 08:15 AM
80ZJoe's Avatar
July 2010 ROTM
^^ its running but not the greatest, the rpm's are to high while in park but good in gear.
Old May 5, 2011 | 08:12 PM
lobby350's Avatar
Ok so I just vacuum tested the pull off and it doesnt hold a vacuum. Just ordered a new one, so when i get that on there i'll report back, hoping that fixes my problem.
kjvforme
Jul 6, 2011 08:26 AM
mtn_maro
Oct 25, 2009 06:34 PM
Ejam
Aug 18, 2009 06:55 PM
hipirn
67-69 V8 Tech
Mar 25, 2008 03:12 PM
WayFast84
Feb 25, 2006 11:00 PM
