Plexigalss windows...
Old Dec 2, 2007 | 04:13 PM
CamaroKid81's Avatar
Default Plexigalss windows...
I have an 81 Camaro...I was on a site where they had like some sort of plexiglass windows...
does anyone know of a site where I can order some?
Old Dec 2, 2007 | 05:27 PM
1969 SS's Avatar
Default RE: Plexigalss windows...
why would you want them?
they are only useful on racecars. they don't sealanywhere near tight enough for regular drivers.they also don't go up and down and you need to build frames for them so they stay stiff enough.
Old Dec 2, 2007 | 05:34 PM
well...my driverside window is all messed up...we replaced the amrs inside the door put they were bad anyways...so I thought if I could have lighter windows it wouldnt be so bad....I didnt know they couldnt roll down or about the seal thing...
Old Dec 2, 2007 | 05:54 PM
You can get away with plastic in the back windowbut if you use it as a side window you will have to replace about every 4000 miles or so. Small pc of dirthit your glass as you drive. Real glass is hard enough to resist scratching. Even as a rear window plastic is only good for about 50,000 mile. I have seen rear window on convertables you could not see out of.Most newerrag tops have glass rear windows because of this.
Old Dec 3, 2007 | 12:52 PM
Oic....Thanks for the help guys....
blackheart2358
Sep 27, 2012 10:30 AM
thebandit110
Aug 28, 2010 09:52 PM
67Harbor
Aug 15, 2010 05:54 AM
KS77
Nov 10, 2007 04:49 PM
94Red
Jun 22, 2007 12:40 AM
