Part Identification
Old May 23, 2011 | 09:13 AM
walkingchaos's Avatar
Default Part Identification
Ok so Ive been cleaning up the car over the last few weeks and have been finding all the bits and pieces which are broken or needed replacing. Yesterday I found something I hadnt even noticed due to a buildup of leaves and dirt At the bottom of the windshield there is a recessed area with a plastic grill over it. Inside are the mechanics for the windshield wipers and Im assuming air passage for the HVAC inside the car. The car sat under a tree for many years so this entire area was filled with dirt and leaves and debris. On the passenger side I found a metal flap door connected to what looks like a small actuator and spring. Im thining its maybe part of the defroster ? Anyway its totaly rotted out from being under wet dirt/leaves for so long. My question, what is it and where can i get a replacement ? Thanks guys!
Old May 23, 2011 | 12:45 PM
I don't think they repop that. It is for the ac though. When you turn on the ac the door shuts.
Old May 23, 2011 | 01:03 PM
Ah good to know, so since i dont have AC ill just pull it thanks!
Old May 23, 2011 | 02:16 PM
gfrench's Avatar
it has a vacuum line running to it. You will need to plug that vacuum line or you will have a vacuum leak.
Old May 23, 2011 | 04:36 PM
the line running to it looks almost like an electrical line ? is it not ?
Old May 23, 2011 | 09:43 PM
spifff2003's Avatar
it should be a flexable plastic vacuum line
Dave
phord
82-92 V8 Tech
May 21, 2014 04:25 PM
elopez89
Nov 2, 2012 12:49 AM
Ecidemon
Sep 3, 2012 04:16 AM
1993_Z28
Aug 4, 2012 12:17 AM
