OER Dash
I sure hope they fixed that fitment issue a while ago, mine came in a box with the car when I bought it. I still have to put it in. I have no idea when it was originally bought! I hate the thought of having to cut new parts.
If your are talking about the lower dash part with the glove box hole in it its best to attach it to the upper part before you install the clips in the metal under the windshield. after it is tighten up then you can go ahead and install the two parts as a whole. I jus put my dash in and realized that after the fact.
Yeah Camaro Kid I did the same thing. The only fitment issues I really had was it was too long side to side so it caused it to bow up. Then the stud on the far left had no hole to go into. I just cut out a slot in the dash for the stud so I could adjust back and forth. I cut the end material off inside the car on both ends with a coping saw. Did a pretty decent job and the inside trim will cover it. The screws that go from the pad to the lower panel are about a 1/8 inch off. A little prying with a plastic panel remover got them to line up. All in all not to bad just put it together out of the car first and it will be easier.
