If you saw it up close , you would see it..
It is hard to tell in the photo.. But the picture does make it look molded ..don't i wish
#106
So it is home in the garage...
I go out in the morning to test run things..
First impressions is it handles great.
I may need to adjust the timing, more advance, but i won't know more until early manana...
I will report back then..
#107
I drove it early this morning... Through a local set of highway cloverleafs.....
Over and over and over and over.....
Wow... Like glue. Tested solo, and worked on the timing, and picked up a friend...
Sticks like glue.. No real launches yet, but they will come...
So on the way home, a charger pulls up at 70 with drivers gloves on, and asks me if I want some ?? Sure I do, but not on the highway starting at 70...
He should have been at the cloverleaf when all you could smell is rubber, and I was WOT, and banging gears up to the next turn....He would have gotten his piece then..
More tests later..I used 40 dollars in gas haha.
Oh and I broke the window crank when I got home...Still got some things to do...
Carnival Ride is what it is.
My friend says ....wow you can't drive into the turn like that....As we are doing it, i yell "we just did "...
#109
I really wish I could...It was great...
