New project 75 lt 350 zz3 4spd car
Old Sep 29, 2010 | 05:43 PM
80ZJoe's Avatar
July 2010 ROTM
You should try self tappers insdead of rivets, seam seal and grind, if you were near me i would weld it for you but im just learning so i don't know how good it would be lol.
Old Sep 29, 2010 | 09:50 PM
75CAMAROLT's Avatar
Tonight i decided to attack those rear shocks i thought were loose and guess what i did snapped one of the bolts dammit! but i lucked out i took the shock out heated the remaining stud with my home depot torch and it came out with the ol vise grips after heating it three time.
i also took the back seat out in the event of a fire. put new bushing at the bottom of the shock now i'm good to go whew!!!
that couds have been a real downer i think i figured out what the banging might be i think since there is a small shackel on the rear leaf springs the shocks are getting all the way extended and when it comes back up from a bump it extends all the way and kinda hops and bangs. maybe the wrong shocks. the shackle is about 6 ,7 inches should it be that long?
Old Oct 3, 2010 | 09:35 PM
75CAMAROLT's Avatar
ok i decided it was time to work on the car some more the heater didn't work when i got it so it turns out sombody didn't have the vacume hose hooked up that pulls the actuators from def to heat that was easy.
But i did also look into the dash lights and gauges not working it turns out the guy before me or before him cut the main harness head plug that plugs in to the cluster ???? why do people do this stuff i have no clue .
so now i either have to get a whole new harness $500??? or get the head that plugs in and start splicing what a night mare??? help please anybody with suggestions!! I would like to hook up the stock gauges like fuel tach water etc or i can get all after market ones (not!!!).
Old Oct 4, 2010 | 06:19 AM
Dejavu?
Old Oct 4, 2010 | 06:36 PM
Clutch should be adjusted so that you can push the pedal in with light pressure and it moves about 1/2" of freeplay before feeling any pressure. That should get the clutch to engage higher off the floor.
Old Oct 5, 2010 | 06:58 AM
75CAMAROLT's Avatar
sounds good how many springs do i nedd on that bad boy one from the fork to the z bar? or do i need the one that make the whole thing swing toward the front too? when i put the second one on i did not care for the pedel so high off the ground
Old Oct 5, 2010 | 09:55 AM
I put min from the fork to the subframe. If you look just right you'll see two little holes for the spring to go to.
Old Oct 5, 2010 | 12:30 PM
75CAMAROLT's Avatar
that's what i did there is a small hole in the fork and the z bar
Old Oct 5, 2010 | 01:44 PM
I put the other end on the fork if thats what your asking. From the fork to the frame thats it only one spring. I'm not 100% sure it in the right spot on the sub frame , but man it sure does look right.
Old Oct 5, 2010 | 08:31 PM
  #20
75CAMAROLT's Avatar
Yes it sounds like you are doing the work of two springs.
that works too. anybody have a diagram of it?
