Need Suspension help on 1970 RS.
Old Apr 10, 2010 | 12:44 AM
jhong321's Avatar
Default Need Suspension help on 1970 RS.
Hello All
I am very new to the 2nd gen camaro and just picked up a 1970 rs with a 383 4sp. In the past I have always been a vette guy and just sold my 2000 FRC (pushing over 600 RWHP) My question would be how can I make this camaro handle better? I am into road course racing (t-hill mostly)and i do understand it won't come close to the vette but I just need it to handle better. I do understand there is a coilover kit for the front but how is it? is there a better way? I have a budget of about $2,000 to do this. If there are any of you out in the bayarea I would like to take you out to lunch and pick your brain.
thanks
Old Apr 10, 2010 | 01:03 AM
Osmiumfoot's Avatar
Subframe connectors and polygraphite bushings will help, along with fatter sway bars. You can make 2nd gen Camaros stick like a childhood nickname if you take some care in setting them up correctly.
Old Apr 10, 2010 | 03:05 AM
jhong321's Avatar
Sounds like a good start. I will definitely do that. but how about the shocks or coil overs? I am looking to get the best handling without going to a full custom fab.
thanks
Old Apr 10, 2010 | 07:02 AM
Acually the exact set up I'm putting under my car regularly whoops on Z06 vettes all day at the autocross. potouringf-body.com I have there entire comp set up, added to thet is a 12:1 ratio steering box, billet tie rod sleeves, g-bars, g-bar brace, tubular upper and lower control arms, and solid sub frame bushings. When I called Dave at ptfb I told I was specificly after handling on par with Z06's and Porche 911's. I hunt them with a mullet wig on ya know. I spent about $3300 for all of it, but they are considered the best bang for your buck out there. I would have run the race set up but they have a solid type front spring bushing and control arm bushing, there is no way of keeping water out of them. I just read your last post. It is a complete bolt on. And if your going to run sfc use a solid mount not poly.
-Good luck and welcome to the forum
deathlepricaun13
Nov 1, 2009 10:12 AM
Furr1970
Oct 18, 2007 05:46 PM
70camaro
Aug 15, 2007 11:59 AM
draakarmaul
Feb 2, 2006 03:34 PM
