Need to lean out at 2500 rpms
I drop the spring weight down 2 sizes. It had the stock spring. I went with the blue spring and passed with flying colors. I had 0.00 for CO2 readings.
I am a Holley guy, but this carb came on the truck, it runs great. It is just a daily work truck so no reason to mess with what isn't broken.
I want plates. 74 and newer have to pass emissions in Colorado and most states. This carb is on my 81 C10. But I have to get my 78 Z to pass later this month. That will be fun. Will probably have to take the 750 off and go with something a lot smaller.
Does Co. have "special use plates"? I changed my Austin and the Camaro to special use plates this year. The Austin got antique plates, and the Camaro I put the original '71 plates on. In Oregon cars with special use plates are exempt from DEQ, and it's only $82 for one plate for the life of the car. Here, anything over 25 yrs. old can have a special use plate.
If you're drag racing a Holley will get a lot of tuning, but so will any carb used for racing. Racers just like to constantly try to fiddle with their engines to get more power.
At least a Holley can be tuned easily if needed, unlike an Edelbroke.
I would have to disagree with you on this one! I have had multiple edelbrocks that wont even adjust the idle circuits anymore and spit fuel n fire back through the breather. And no it wasn't a timing issue either! dropped a holley on the maro and its 10x better already.
But really with removable air bleeds and emulsion bleeds, I guarantee once I have it dead on. It will stay there. I can see the circuits and how they work in my mind with Holley carbs. This makes it easier for me to visualize what I need to do to fix something. I can't with an Eddy.
With a wideband A/F gauge that has a digital display along with my timing light I could tune it, but i would have to spend some time on their website reading.
