might be missing heat shield?
Old Dec 31, 2008 | 12:14 AM
jason7504's Avatar
Default might be missing heat shield?
i think my '81 camaro is missing a heat shield because when its hot out or when the engines hot the car has trouble starting but starts good in the cold. does this sound like its missing a heat shield? and how do i replace it?
Old Dec 31, 2008 | 12:06 PM
Default RE: might be missing heat shield?
What starting problem are you having?Starter is notcranking the engine, or is the starter cranking the engine being but the engine won't start?
Old Dec 31, 2008 | 01:00 PM
73camaroSS's Avatar
timing sounds like it is off,seeing as how it only has problems when it is hot.
Old Dec 31, 2008 | 01:34 PM
jason7504's Avatar
z28pete, the starter is cranking the engine but it wont start..
73camaroSS, really? that would only affect it when its hot..so the heat shield or lack there of, isn't the cause?
Old Dec 31, 2008 | 04:08 PM
73camaroSS's Avatar
if the timing is off it well start good when cold but will turn really slow when you try to start it after it has warmed up,but as soon as it cools off it starts up just fine,is this what your car does or does it not turn at all when it is warmed up.
Old Dec 31, 2008 | 05:02 PM
jason7504's Avatar
that is what my car does, it turns but wont start when hot but then starts good when its cold out or when the engine has cooled off..
Old Dec 31, 2008 | 05:29 PM
73camaroSS's Avatar
do you have the tools you need to check the timing,and to see if you have the heat sheild take your lazy butt out side get under your car and check and see if it is there,but i really think you need to adjust your timing.
Old Dec 31, 2008 | 05:34 PM
jason7504's Avatar
no i dont..wouldn't they have checked it though when i got my MSD distributer installed? lol ouch! :P ok well if it isn't there would that affect it too?
Old Dec 31, 2008 | 05:40 PM
73camaroSS's Avatar
well you keep asking about it go see if its there.how long has it been since you got the msd installed,and was the problem there before the msd or after,and did it start after the msd got put in,if so i would go back to the shop that put it in and tell them your problem and ask them nicely if the could adjust it for you.
Old Dec 31, 2008 | 05:44 PM
jason7504's Avatar
well i was just wondering if that would have caused it..its been around 3 months and if i remember correctly, it was there before i got the msd
