manual tranny for 69
Old Oct 4, 2006 | 11:12 PM
69camarokid's Avatar
Default manual tranny for 69
does anyone know what kind of manual transmissions would fit into a 69 camaro... i currently have a turbo 350, 3 speed manual and its got to go, i want to swap in a 5 or 6 speed... any idea on what trannies will mount up in there to a 350. thanks
Old Oct 5, 2006 | 11:58 AM
1969 SS's Avatar
Default RE: manual tranny for 69
a turbo 350 is an automatic so you have me confused?
Old Oct 5, 2006 | 11:20 PM
yeah im a tard... sorry, i meant to say a three speed automatic, i was just thinkin about manuals.... but im trying to findout what kind of manuals from cars are able to be directly swapped into my 69 , or ones with little modification... any ideas
Old Oct 12, 2006 | 11:13 AM
69camaro1's Avatar
Well as far as I know you could probibly fit a taramac 5-speed in their just fine or with little modification. But I have never done this kind trannie swap.
Old Oct 12, 2006 | 10:24 PM
uncle bill's Avatar
Probably the biggest issue You'll have is setting up a clutch pedal and linkage. There are a number or 4, 5 and 6 speed trans that will fit. All You have to do is get the driveshaft setup for it. A Muncie M21 or M20 ( both common ) uses the same yoke as a T-350. A Super T10 uses the same yoke as a T400. Use a Hurst shifter ( they've been doing it since day 1 ) and get a good aftermarket bellhousing ( McLeod or Lakewood ) and don't skimp on a clutch setup. This will be a relatively expensive swap so I'd price it all out before I began to do anything. Good Luck.
John4649
Dec 16, 2012 01:49 AM
vXIcetreyXv
May 11, 2011 09:38 PM
lilman316
Sep 19, 2009 01:08 PM
nebt3x
Feb 21, 2007 05:59 PM
akohnz
Apr 29, 2006 07:15 PM
