Lowering your Camaro?
Old Aug 24, 2010 | 11:41 PM
Dustinho's Avatar
Default Lowering your Camaro?
I will be lowering my camaro all around either 1" or 1 1/2". I planned on replacing the coils to lower stance.
How do spindles work to drop car? What is the best and cheapest way to go?
Thanks for you help!
Old Aug 25, 2010 | 03:01 AM
I wouldn't use a drop spindal. The factory GM spindal has as good of geometry as it gets for these cars. ProTouring F-Body has springs for the cheapest. To answer your question the springs are simply shorter. The leafs in the rear have less of an arch to them. Check out my project thread, its in my signature. My car is lowered a bit. Its hard to tell with the wheels and tires on there, but there sre some pics of the springs in there.
Old Aug 25, 2010 | 11:48 PM
Dustinho's Avatar
Thanks 77 Nomad. Saw the pictures and they look great. Do I need to change the leaf springs to lower it as well? They are the original stock ones now.
Old Aug 25, 2010 | 11:56 PM
JRs72RS's Avatar
February 2009 ROTM
You can lower your front without buying springs. All you need is an acetylene torch to heat the coil just above the point where the coils separate at the bottom of the spring. Heat the spring just enough to drop the coil on top of the lower one, this will yield about one inch of drop. For the rear the best is to buy new since many of the original leaf springs were weak anyway and altering them ruins either ride or handling.
Old Aug 26, 2010 | 10:18 PM
Summit Racing has lowering springs for the rear on sale right now. I just got a pair for mine at $85 ea.
Old Aug 29, 2010 | 04:28 PM
brownstone101's Avatar
hey good sir. do you think you could explain a little more. im curious how to do this. but i have yet to see how our springs are installed and how that would work,
thanks
Cat900
Oct 8, 2014 05:18 PM
fuzz1313
Dec 13, 2011 09:25 PM
RFxCamaro
Sep 26, 2011 09:48 AM
Dustinho
Nov 29, 2010 11:55 AM
skillz
Jul 2, 2008 10:02 PM
