junkyard upgrades
a good set of headers available at most junkyards.also lots of times u can find a good 750 holley at the junkyard even a good quadrajet carb can be found there and there easy to rebuild and upgrade.
Engines, trans, rear axles, bucket seats, disc brakes, etc. Used to be easier when there were hundreds of 2nd gen Camaros and Firebirds, but still some generic items that are useable if you're not worried about a numbers matching resto.
Local Craiglist is great for performance items like engines, intakes, carbs, headers, wheels, etc. I find more there than I do at junkyards, and always cheaper if you're patient.
You can get a set of B body spindles and then use a Iroc rotor. This gives you a 12" front rotor. Known a a 1LE upgrade. Then a set of s10 rear discs or Ls camaro discs. This will set you back 500 or so.
Just pull the pitman arm, install the box, then put the Camaro arm back on the S10 box.
That's the only plus; quicker lock to lock. I personally like the stock box, but I don't slalom. If you're going roadracing or slalom, the S10 box is the hot ticket.
