junkyard upgrades
hey all im trying to fiqure out what junkyard upgrades can be used for our 2nd gens.. Im not looking any one part just some things people have used to improve there cars.
a good set of headers available at most junkyards.also lots of times u can find a good 750 holley at the junkyard even a good quadrajet carb can be found there and there easy to rebuild and upgrade.
Newer motor with more HP... 4 speed auto... 4 wheel disc brake setup?
Engines, trans, rear axles, bucket seats, disc brakes, etc. Used to be easier when there were hundreds of 2nd gen Camaros and Firebirds, but still some generic items that are useable if you're not worried about a numbers matching resto.
Local Craiglist is great for performance items like engines, intakes, carbs, headers, wheels, etc. I find more there than I do at junkyards, and always cheaper if you're patient. |
You can get a set of B body spindles and then use a Iroc rotor. This gives you a 12" front rotor. Known a a 1LE upgrade. Then a set of s10 rear discs or Ls camaro discs. This will set you back 500 or so.
You can also swap in a later 3rd gen steering box, or S10 steering box and get a quicker ratio steering.
s10 steering box huh? do have any details on that swap, i have an old s10 in the backyard..
Originally Posted by 78bluers
(Post 604769)
ok whats the benny to the s10 is it a quicker ratio
(Post 604906)
